Domzs Posted July 13, 2013 Share Posted July 13, 2013 Those codes won't give you any driveability problems . A tuner should be able to delete them . p0704 and p0803 will not turn on " CEL " but p0480 and p0481 will . Why aren't you using ECM control electric fan(s) ? Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) Those codes won't give you any driveability problems . A tuner should be able to delete them . p0704 and p0803 will not turn on " CEL " but p0480 and p0481 will . Why aren't you using ECM control electric fan(s) ? ECM control for fans according to PO was not sending signals for proper operation, that engine and harness/ECM came from an automatic car . She has an T5/6 spd ,is this an issue to remedy or leave it as it is now Edited July 14, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 14, 2013 Share Posted July 14, 2013 Fans can always be controlled with the computer. Im running a 5.3 harness which is an accessory driven fan and my electric fans are run off the computer. The computer sends out a ground signal not a power Ive seen them wired wrong. Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 Fans can always be controlled with the computer. Im running a 5.3 harness which is an accessory driven fan and my electric fans are run off the computer. The computer sends out a ground signal not a power Ive seen them wired wrong. OK, whats the remedy . The + or - in my set up Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 14, 2013 Share Posted July 14, 2013 Just rewire your relays for a ground trigger and connect them to the correct wires on the ECU. Looks like red 33 is for high speed and blue 42 for low speed. If you are running duel fans run one on blue 42 and one on red 33. DomZ can confirm but I think low speed turns on at 180 factory and high speed is 200 factory both can be changed. http://www.lt1swap.com/2001_PCM_CONN_PINOUT.htm Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) mattd428, THANKS , I will see if can convince one of my local chevy guys on assist with this remedy, I am paranoid when it comes to electronic's Edited July 14, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 14, 2013 Share Posted July 14, 2013 Good luck DomZ is saying it takes 3 relays. Im sure he will chime in soon and tell you how he wired his cars. Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) ^^^ again THANKS, does the aftermarket A/C unit fan function be OK Edited July 14, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
mattd428 Posted July 14, 2013 Share Posted July 14, 2013 No problem this might help. http://www.performancetrucks.net/forums/gm-engine-exhaust-performance-21/ls1-fan-wiring-442148/ Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 ^^^ THANKS FOR THE TIPS Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted July 14, 2013 Share Posted July 14, 2013 Yeah! Glad you are fixed up! Quote Link to comment Share on other sites More sharing options...
Domzs Posted July 14, 2013 Share Posted July 14, 2013 It looks like you are running dual fans setup , modified F body fan assembly . I run mod F body fans on my 83 and single fan ( 3 wires , lo and hi ) on my 78 . You will need 3 relays , as fact switches from series to parallel to get hi and lo speed . A good electrical guy should be able to figure out how to wire it up . Temp on and off can be programmed by your tuner . I'm running 175F T-stat , fan(s) on low at 190F and off at 180F and high on at 200F and off at 180F . PM me if you have any problem . Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 (edited) It looks like you are running dual fans setup , modified F body fan assembly . I run mod F body fans on my 83 and single fan ( 3 wires , lo and hi ) on my 78 . You will need 3 relays , as fact switches from series to parallel to get hi and lo speed . A good electrical guy should be able to figure out how to wire it up . Temp on and off can be programmed by your tuner . I'm running 175F T-stat , fan(s) on low at 190F and off at 180F and high on at 200F and off at 180F . PM me if you have any problem .Thanks Thanks for the info . I ask again , is it OK to leave the current set up via an external none ECM signal for fans and aftermarket A/C unit. I do like the idea of a clear CEL Edited July 14, 2013 by PLATA Quote Link to comment Share on other sites More sharing options...
PLATA Posted July 14, 2013 Author Share Posted July 14, 2013 Yeah! Glad you are fixed up! Yep, glad this mini episode is over, she is acting and running like an award winner porn star . Next on the agenda if absolute necessary is to do ECM commands fix to radiator fans Quote Link to comment Share on other sites More sharing options...
Domzs Posted July 14, 2013 Share Posted July 14, 2013 Thanks for the info . I ask again , is it OK to leave the current set up via an external none ECM signal for fans and aftermarket A/C unit. I do like the idea of a clear CEL Current setup is OK . But your CEL will stay on . With it being on , you can't tell when it has other problems ( DTCs ) . Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted July 14, 2013 Share Posted July 14, 2013 A little piece of black electrical tape on the face of the gauge will fix that check engine light! Haven't hooked mine up. On "the list". Quote Link to comment Share on other sites More sharing options...
