awd92gsx Posted April 18, 2002 Share Posted April 18, 2002 Hey guys, I'm buying an L28ET, but I guess the distributor from the '83 L28ET is missing...Is there any reason I can't run the distributor from my '77 280Z in it? Is there any kind of modding that needs to be done to the dist. to get it to work with the 280ZXT ECU? Thanks in advance, and...I'm still learning about Z's...so I apologize if this appears to be a "newbie" question... Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted April 18, 2002 Share Posted April 18, 2002 The N/A distributor will not attach to the shaft, so you need a shaft as well as a distributor. I do not believe the crank angle sensor will install into the N/A distributor either. If you are using the factory electronics, the non-advancing distributor is nice, but if you really can't find one, you could use a N/A ZX distributor with an MSD boost retard and ignition box and just not use the turbo ignition curve. Quote Link to comment Share on other sites More sharing options...
