Dreamsmasher Posted July 17, 2013 Share Posted July 17, 2013 Well I've finally finished removing my intake/exhaust manifolds to replace my leaky old gasket. Now I'm kind of nervous about progressing any farther. I am looking at the bolts that came out of my exhaust maifold and the ones I ordered to replace them are studs. So what gives? I have P79 heads (car is an 82' N/A) and all I could find was studs, so I went ahead and ordered them. You could imagine my suprise then when I removed not studs but bolts from the exhaust manifold. Am I missing something here? Do I just install these studs in place of the bolts? Or did I goof up my order somehow? Also the bolts at both ends of the exhaust mani. were sheared off beneath the surface. What is the best way to remove these? My default solution is to drill them out as carefully as I can with a left-handed drill bit, but I was hoping someone might have a better way (or maybe just some solid advice on actually doing that)? Lastly any advice on the best way to clean up the mating surfaces? I was thinking a can of brake cleaner along with some razor blades for scraping will do the trick, any objections? Quote Link to comment Share on other sites More sharing options...
BluDestiny Posted July 26, 2013 Share Posted July 26, 2013 There should be studs there. It makes it a heck of a lot easier to remove and replace the manifolds. You can clean it with a scotch brite pad and a hard plastic scraper. Razor blades work also Quote Link to comment Share on other sites More sharing options...
Pilgrim Posted August 12, 2013 Share Posted August 12, 2013 I'm in the same place you are - but with an '83 ZX Turbo. I spent months getting the dang manifolds loose, then gave up and pulled the head with manifolds still attached. The answer is...the end connectors were studs in the first place. Everything but the last connector on each end is a bolt, but those are studs. They often break off, which is why I pulled the head - I'm not crazy enough to think I can free-drill those studs out when they've been stuck in there for 30 years. The good news is that a Z specialist I am working with says that normally, replacement connectors do not break off...probably has something to do with the metal the studs were made with. Take the head to a machine shop and have them drill out the studs, heli-coil if needed, then (my advice) re-mount the manifolds and re-install them all as one unit. I'm going to rent a cherry picker for the re-install, as there's no way I can hold everything in place. Quote Link to comment Share on other sites More sharing options...
