V07 Stroker Crank Value?
Chemicalblue
I'd love to put the entire LD28 in my truck if I didn't have to chop and if the injector pumps were able to be remanned.
Or maybe it was the SD's that you were out of luck if/when an injector pump goes out....
I paid $350 for mine back in 2007. I get shop rate for my machine work since my father is a frequent business customer.... $400 to hot bath block, bore block, polish crank, pressure check head, shot peen rods, press on pistons.
