sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 Pretty sure you missed my point... Your point seems pretty clear. "don't think that you understand the basics of fuel injection, or your not applying the principles to your problem. You should read read the Engine Fuel chapter in the FSM." That's ok man I still love u Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 9, 2013 Share Posted August 9, 2013 My direct point in the later post was that the fuel damper can only restrict flow if there is a problem with it. But you stated that you had good flow from the injectors in a previous post. So you were planning to remove something that could only restrict flow even though you don't have a flow restriction. No beneficial effect. In other words, you're wasting your time removing the damper. And you didn't address my point about what the injectors were doing. At low RPM you should see the individual squirts. If you get a full blast when you turn on the pump at starting RPM then you have an electrical problem with the injectors. Could be as simple as the TPS being stuck on WOT. Quote Link to comment Share on other sites More sharing options...
sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 My direct point in the later post was that the fuel damper can only restrict flow if there is a problem with it. But you stated that you had good flow from the injectors in a previous post. So you were planning to remove something that could only restrict flow even though you don't have a flow restriction. No beneficial effect. In other words, you're wasting your time removing the damper. And you didn't address my point about what the injectors were doing. At low RPM you should see the individual squirts. If you get a full blast when you turn on the pump at starting RPM then you have an electrical problem with the injectors. Could be as simple as the TPS being stuck on WOT. Well, it sounds like youve never "grasped at straws" that's all the fuel damper thing was, a straw. Sometime getting distracted helps u figure out what the main problem is. Btw, stock ecu is non-sequential, all injectors fire at once. If you read the manual........ Quote Link to comment Share on other sites More sharing options...
sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 Nite folks, ill hit it again after work tomorrow. Thanks for all the advise. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 9, 2013 Share Posted August 9, 2013 Btw, stock ecu is non-sequential, all injectors fire at once. If you read the manual........ Exactly. You're getting worked up at someone who's on your side. Quote Link to comment Share on other sites More sharing options...
sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 (edited) Exactly. You're getting worked up at someone who's on your side. "you aren't really thinking things through. " What's good for the goose is good for the gander. Edited August 9, 2013 by sekkyoshi Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 9, 2013 Share Posted August 9, 2013 Word. Quote Link to comment Share on other sites More sharing options...
sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 (edited) Wait a tick! Was cleaning up and I picked up stuff from in front of the car and I noticed the afm flapper door was in the up position... Bingo! Put in spare afm and Vrroom! The afm spring is unhooked or broken, the would explain the sudden death and the injectors acting weird. Ill post a video in the am. Thanks again everybody hopefully this will save some poor slob 3 days of barking up the wrong tree(s). Edited August 9, 2013 by sekkyoshi Quote Link to comment Share on other sites More sharing options...
sekkyoshi Posted August 9, 2013 Author Share Posted August 9, 2013 Bad afm http://m.youtube.com/watch?v=Kg1pboJjl-U [Youtube]http://m.youtube.com/watch?v=Kg1pboJjl-U Quote Link to comment Share on other sites More sharing options...
mattb3562 Posted August 11, 2013 Share Posted August 11, 2013 Yeah I may have missed it earlier in the post, but I would need to see fuel pressure numbers from before/ after fuel filter and rail. Yeah also testing the AFM would be a good place to start. I ditched my eccs, so I honestly can't remember how the warmup enrichment works...if it has a thermo time switch or gathers data from which temp switch but after all of that is confirmed good...fuel pressure, AFM, and the warmup system, (thermotime stuck on my 76 and caused the same type problem flooding) then I would wonder about the eccs itself, although they're pretty tough Quote Link to comment Share on other sites More sharing options...
