No fuel problem in 1971 FairladyZ .. need help please
Z sat in garage for a couple of weeks and would not start.
No fuel flow getting to the carbs.
Replaced original mechanial fuel pump and filter and still no gas flowing.
Gas seems to flow okay from tank to filter.
Don't see any leaks.
Put new hoses on all fuel lines in engine compartment.
Lost as to what to look for next.
Could it be a problem actually in the engine?  Camshaft is turning.  Can't see the arm on the pump ... have to pull valve cover to check that; rather not ... but ...
Any suggestions would be greatly appreciated.
We've been able to drive it three times this summer (battery dead cell problem, brake light problem, ignition problem, and now fuel problem ....)
Thank you!!
