4G63 +0.040 pistons on L engine
s30red240z
I'm running +1mm oversize Z22S pistons on the L24 rods and L28 crankshaft, the +2mm bore is the biggest that you can run on a stock headgasket, and allows more valve unshrouding when porting.
Are those pistons available in a 88mm bore, and forgings?
Forged, yes are common 4 set, bore size 85, 85.5, 86, and 86.5, in the near future i gonna over bore L24 block to fit 85mm pistons
