Passive Ram Air
Dave
Excellent. If rainwater does get in, it's going to collect in the housing. The best way to locate the drain hole or slot(s) may be to remove the element, pour a cup of water in the top hole, see where it wants to pool, and put the drain there. Sometimes the actual lowest point isn't the intuitive lowest point. DAW
I just mounted a cone filter in front of the rad like the FI guys do. I had a damaged SU manifold that I cut the heat riser off of and connected a hose to my K&N after removing the internal filter. When I swap in my triple Del'Lorto equipped 2.8 I'm going to make an aluminum air box that is connected to the same cone filter.
