Guest Anonymous Posted July 31, 2002 Share Posted July 31, 2002 Got the oil relocation kit put back on but i need a new o-ring for it!! Any body know where i can get one??? PLEASE HELP! thanks, franklin Quote Link to comment Share on other sites More sharing options...
blueovalz Posted July 31, 2002 Share Posted July 31, 2002 This may help. My oil relocation kit O-ring (it was from Trans-adapt) was so compressed that it no longer provided a good seal (spin on adapter would bottom out on the block without crushing the shrunken O-ring). I found that the oil filter O-ring taken out of the groove of an oil filter worked very well, and tightened the whole system up nicely. I can't remember the oil filter number but it was one for a 240SX or a Pathfinder filter. I happened to be the exact same diameter and almost perfect width and thickness. Quote Link to comment Share on other sites More sharing options...
denny411 Posted August 1, 2002 Share Posted August 1, 2002 If it`s for a sbc, you might try going to a gm dealer and getting an oil filter extension housing o ring for an 88 k1500 pickup. Gasket and o ring is about 4.00 Quote Link to comment Share on other sites More sharing options...
yo2001 Posted August 2, 2002 Share Posted August 2, 2002 all you need is oil filter o-ring right? It should be the same as an adaper o-ring. Motorcraft FL1's o-ring comes right off. Under $4. Quote Link to comment Share on other sites More sharing options...
