skirkland1980 Posted November 2, 2013 Share Posted November 2, 2013 Hello. I just finished assembling a ms2 v3.0 board for my 1983 datsun 280zx turbo. My car already has a ms2 v3.57 and is running good. I removed the daughter card from the v3.57 and installed into the new v3.0. The car will not run or connect to tuner studio. Same results with the stim. I preformed the voltage and ground tests as per the assembly instructions at the 40 pin socket, all are good. I also checked 5v and ground at the db9 and is good. Everything appears to be installed on the board and soldered well with no bridging. The only leftover parts I have are for the squarewave ign input which I am using vr. Thanks....Shane Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted November 2, 2013 Share Posted November 2, 2013 Did you loop back the serial port as per the instructions? If it won't connect to tuner studio then its a problem with the serial port assembly. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 2, 2013 Author Share Posted November 2, 2013 I didn't do that. I did ohm the db9 connector. The car should still run. I'm using a known good processor. Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted November 2, 2013 Share Posted November 2, 2013 (edited) U6 may be having some issues. Check its VCC input. You might be having voltage issue, I fried the 5v power supply and it would make 5v until it pulled a load. Did you check voltages in other areas with the processor installed? There are a few jumpers you could check. Edited November 2, 2013 by winstonusmc Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 2, 2013 Author Share Posted November 2, 2013 I only cheeked at the processor and the serial connector. I check into it some more tonight. Thanks Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 4, 2013 Author Share Posted November 4, 2013 Update: I cleaned the board with acetone and tried to connect. Now it says it found the controller but there is no firmware loaded. I pulled the processor out and put it in another 3.0 board and it still connects fine. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted November 6, 2013 Author Share Posted November 6, 2013 I've made progress. Apparently xg1 and xg2 need to be jumpered. The only place in the assembly instructions this is mentioned is under hall sensor, optical sensor applications. So I jumpered them and now I'm communicating. New problem, no tach signal: I have tachselect jumpered to vrin and tsel to vrout. I also adjusted the trimpots. Thanks, Shane... Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted December 14, 2013 Author Share Posted December 14, 2013 Looks like I may have broken the trim pots. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 16, 2013 Share Posted December 16, 2013 It is OK to turn the trim pots too far, the just slip/click at the end of the range. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted December 17, 2013 Author Share Posted December 17, 2013 I removed r56 and measured resistance while making adjustments and I don't get any change. I'm not sure what's going on. Quote Link to comment Share on other sites More sharing options...
mobythevan Posted December 17, 2013 Share Posted December 17, 2013 I'm not trying to be condescending, but if you are on the wrong leads of the POT it will not change while making adjustments. You need to measure between the "wiper" and one of the other two leads (either one works) Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 2, 2014 Author Share Posted February 2, 2014 Started working on this again. Now it will not connect to tuner studio. I pulled the cpu out and put it in the 3.0 board that I fried at that one will connect fine. Same thing happens when I try a ms1 cpu. Maybe u6 is bad? All the diodes and polarized caps are oriented correctly. Quote Link to comment Share on other sites More sharing options...
loy Posted February 2, 2014 Share Posted February 2, 2014 Yes please check the max232 ic(u6). http://www.megamanual.com/connect.htm Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 2, 2014 Author Share Posted February 2, 2014 Great! It's communicating again. My problem was here, continuity between pin 12 of the MAX232 to CPU pin 13. A bad solder connection. Now back to the issue of tach input. Still no rpm on the stim. Thanks again loy. It's hard for me to fine what I need sometimes from my phone. Quote Link to comment Share on other sites More sharing options...
loy Posted February 2, 2014 Share Posted February 2, 2014 What are you using as input VR or hall Effects? Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 3, 2014 Author Share Posted February 3, 2014 I'm using an 83 vr distributor. I'm thinking about using a gm hei module and maybe a pullup resistor for tach input. Any idea how to do that? Quote Link to comment Share on other sites More sharing options...
loy Posted February 4, 2014 Share Posted February 4, 2014 On 11/6/2013 at 12:36 AM, skirkland1980 said: I've made progress. Apparently xg1 and xg2 need to be jumpered. The only place in the assembly instructions this is mentioned is under hall sensor, optical sensor applications. So I jumpered them and now I'm communicating. New problem, no tach signal: I have tachselect jumpered to vrin and tsel to vrout. I also adjusted the trimpots. Thanks, Shane... Is this still true on your setup? If so remove the xg1 to xg2 jumper. To do a pull up a resistor, take the line you want to pull up and connect a resistor (1k) to it and 12v. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 4, 2014 Author Share Posted February 4, 2014 It's still connected. I will remove it and retry. Thanks Quote Link to comment Share on other sites More sharing options...
Metro Posted February 4, 2014 Share Posted February 4, 2014 With a VR sensor you don't really need to do anything other than connect the correct jumpers. The stim should give you rpm without any trouble, but in car, you will need to play with the trim pots a bit to clean up the signal. So basically, if you don't have any RPM on the stim, you might want to check the whole circuit for bad components/solders. Quote Link to comment Share on other sites More sharing options...
skirkland1980 Posted February 11, 2014 Author Share Posted February 11, 2014 Ok. I cut the xg1/xg2 jumper and it still connects to TS. I stand corrected there from my first post. But still no rpm on the stim. I'll try it in the car when the snow melts. I think I'm going to try a gm 7pin module to trigger ms. Quote Link to comment Share on other sites More sharing options...
