jkgts1 Posted November 28, 2013 Share Posted November 28, 2013 Okay, I have a 260z and I know the brake booster vacuum hose size is 3/8", but I only have a 1/4" nipple available on the intake manifold. I swapped in a 2jzgte. Can I just use a 3/8" to 1/4" reducer or will that not be sufficiant? I really don't want to pull off the manifold to drill and tap a new hole if I don't have to. Thanks Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted November 28, 2013 Share Posted November 28, 2013 This should be the ticket: http://autobahn88.com/catalog/en/533-10mm-to-6mm-aluminum-vacuum-hose-joiner-reducer-adapter-autobahn88-alj-6-10-.html 3/8"= 9.525mm, 1/4"=6.35, so the the bigger end might be a bit loose, but plenty of room for clamps Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted November 28, 2013 Author Share Posted November 28, 2013 This should be the ticket: http://autobahn88.com/catalog/en/533-10mm-to-6mm-aluminum-vacuum-hose-joiner-reducer-adapter-autobahn88-alj-6-10-.html 3/8"= 9.525mm, 1/4"=6.35, so the the bigger end might be a bit loose, but plenty of room for clamps thanks for the reply, but do you think that going down a size will effect how the booster operates? Quote Link to comment Share on other sites More sharing options...
m1ghtymaxXx Posted November 28, 2013 Share Posted November 28, 2013 I would be surprised if it does, but I really couldn't say. Quote Link to comment Share on other sites More sharing options...
jkgts1 Posted November 30, 2013 Author Share Posted November 30, 2013 thanks for the help figured it out with the help of another member. Quote Link to comment Share on other sites More sharing options...
