Suitable 280Z Fuel Pump
Finally got everything hooked back up with a Fram G3 fuel filter between the pump and the tank and used a replacement fuel pump my friend had on his car before swapping in an MSD2225 for his L28ET swap. Unfortunately, it's missing the banjo fittings and those seem to be the key in making the pump not leak gas everywhere when it's running. :icon51:
Starting to think I should just go the MSD2225 route as well. My only concern is that the bracket on my car does not seem to work with pumps that have straight outlets (the stock pump has a 90 degree outlet).
Here's the stock bracket setup.
