question for anyone running a larger turbo...
EvMcMan
Can someone please let me know if I should be worrying about how close the compressor side of the turbo is to the exhaust manifold??  Its nearly touching and there is no way to fit the original heat sheild without modifications.  I was thinking to fit a spacer but the bolts are integrated to the manifold.  Any suggestions or what others have done would be appreciated, or should I not worry about it?  Also, it is a turbonetics t3/04.
I removed the 4 original studs and installed longer ones when i added my spacer.
You may be able to have a regular spacer cut in half, that might be just enough to get away with not needing longer studs.
Maybe you can stack a few metal gaskets onto the manifold.
