RB26DETT assembly video - orange head gasket
NewZed
Thanks for that.  The RB engine seems so much more sophisticated than the L, it's weird that smearing the head gasket with sealant is recommended procedure.  Seems crude, but I assume it's effective.  I should probably be doing that with my L6 intake/exhaust gaskets, which always seem to leak a little bit.  The two that I've done.
Seems like there's a danger of RTV oozing in to critical passages on the head gasket application.
You are correct.  He looks like he's put a few together...  I did that on my last L6 I've built in the past.  I had a head gasket leak water out at the rear right side, so I pulled the head and used a hi heat RTV on the HKS metal gasket.
It worked on the Nissan factory in/exh gasket too.
