nifrum Posted December 21, 2013 Share Posted December 21, 2013 (edited) What does this plug into? A picture would be greatly appreciated. Comes out of the bottom of the ECU plug. Also, car is loosing power when driving and sputtering. Could this be the cause? EDIT: Sorry it is an '82 280ZX, It also dies at idle after being driven. Edited December 21, 2013 by nifrum Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 21, 2013 Share Posted December 21, 2013 Is it a Pathfinder? Or a Maxima? Quote Link to comment Share on other sites More sharing options...
nifrum Posted December 21, 2013 Author Share Posted December 21, 2013 The ECU code is A11-639-800 Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 21, 2013 Share Posted December 21, 2013 Kind of looks like this one but you'd have to trace back to the pins to be sure. Quote Link to comment Share on other sites More sharing options...
nifrum Posted December 21, 2013 Author Share Posted December 21, 2013 I just can't seem to find the female end. Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 21, 2013 Share Posted December 21, 2013 Page 80. Last clue before 10!!! Quote Link to comment Share on other sites More sharing options...
nifrum Posted December 21, 2013 Author Share Posted December 21, 2013 Page 80 of??? Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 21, 2013 Share Posted December 21, 2013 If correct, the ending will be a disappointment... Quote Link to comment Share on other sites More sharing options...
HowlerMonkey Posted December 21, 2013 Share Posted December 21, 2013 (edited) It's name is "not used" and one conductor goes to pin 10 of the ecu while the other has continuity with the shielding of the 02 sensor. It's probably a plug used only on the assembly line and never get's use again. since the non-turbos use a very similar pinout (almost identical) to the bosch generic ecus found on other cars, you might find out what it does. Edited December 21, 2013 by HowlerMonkey Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 21, 2013 Share Posted December 21, 2013 Spooner... Quote Link to comment Share on other sites More sharing options...
