What is this thing?
str8pipez
So the speedo cable goes into the unit and then another cable goes out from the unit to your speedometer?
If that is the case, you will need to buy a stock speedometer cable to keep your speedometer functioning.
Yes, OR switch that last remaining OEM gauge to a GPS Speedhut and skip the cable. But yes, the left over cable is to short. btw, is there a cap for the speedo connection at the trans?
