yo2001 Posted October 6, 2002 Share Posted October 6, 2002 How would I get the gas out from an engine after flooding the crap out it? I can't get my car to crank now because my EFI flooded my engine (EFI is not suppose to do that!) I've clean the plugs (they were all wet) and checked for sparks and both are good now, (timing is good also) but I got to get the fuel out from the inside of the engine before I can get the car to crank. So how about it? Quote Link to comment Share on other sites More sharing options...
Cody 82 ZXT Posted October 7, 2002 Share Posted October 7, 2002 Pull the plugs and the coil wire then turn the engine over to help dry it out the gas should evaperate pretty fast. Or I guess you could pull the fuel injection harness and then turn it over also. Quote Link to comment Share on other sites More sharing options...
Lockjaw Posted October 7, 2002 Share Posted October 7, 2002 Take the plugs out and turn the engine over without turning on the fuel pump. If you had my little remote starter, it would be easy. Use a set of needle nose vice grips or something to pinch the fuel line closed and turn the engine over. You know if you are thinking you may have flooded a fuel injected car floor the gas pedal, hold it there, and turn it over and usually they start. I guess it goes without saying that when it starts, you will need to let off the gas. Quote Link to comment Share on other sites More sharing options...
