wickiewicked240z Posted February 3, 2014 Share Posted February 3, 2014 I bought a 6an rail from Ross I wanted yo know if I can tap the ends with a m14x1.5 tap is the I.D of the rail to big for that tap. Or can I use a m16x1.5? I have a metric tap set that's why I'm using those sizes. Thanks Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted February 3, 2014 Share Posted February 3, 2014 I used 1/4 inch NPT. Yes, I know you said that you have a metric tap, but NPT barbed fittings are easier to get ahold of. I used a barbed fitting for the in and got the AN-6 to NPT fitting for the return. NPT taps are cheap and available at almost any hardware store. Quote Link to comment Share on other sites More sharing options...
wickiewicked240z Posted February 3, 2014 Author Share Posted February 3, 2014 I don't want to use barb fittings for the feed/return fuel sides on rail i was thinking of going m14x1.5 or (m16x1.5) to 6an to tube nut to 3/8 aluminium tubbing. Quote Link to comment Share on other sites More sharing options...
Metro Posted February 4, 2014 Share Posted February 4, 2014 I'm not really sure what size that rail is for. It says the ID is 0.5" and my 3/8" npt tap says to use a 7/16" bit (.4375). I'm guessing an M14 tap would use a slightly smaller hole, say 13mm. So it will either be just right or you'll need patience and a big wrench. I'm going to be making a new rail in a few days and opted for the -8 size so I can use 1/2 NPT to AN -6 fittings on the ends. Quote Link to comment Share on other sites More sharing options...
xero_xero Posted February 4, 2014 Share Posted February 4, 2014 http://www.engineershandbook.com/Tables/npttap.htm Refer to above for npt http://www.ktmatvhq.com/forum/attachments/sx-suspension-steering-chassis-wheels-tires/4664d1317889637-adding-grease-zerks-stock-ball-joints-tap-drill-guide.jpg Above for drill and tap. I'm a machinist and find information in links conforming f To machinist handbook. I talked to you on facebook last nite. Quote Link to comment Share on other sites More sharing options...
