Dadson Racing - 4 year restoration
Hi Folks,
I wanted to do a big intro here, but I really think I should keep it simple. There is a lot of good reading in other parts of the web (linked to, of course) if you would like to investigate. For now, I would like to share my car with the world. What started 9 years ago is finally complete and I can't think of a better way to celebrate than to share it with you all.
In 2003 my father and I purchased a 260z - my first car - and so began the love affair. In 2008 I thought I had reached the end of the road, I even made a thread about it: http://forums.hybridz.org/topic/71666-dadson-racing-a-legacy-aka-my-car-is-basically-finished-d/
A few years later and I graduated university and scored my first real job, then came ACTUALLY finishing the car. I also started another thread: http://forums.hybridz.org/topic/91610-dadson-racing-2010-revival/
It's been 2 years since I posted on this forum; time, money and motivation all ran low and it looked like the car would not be complete in time before the inevitable move to Houston, TX with the company I work for. Realising this, in 2013 my old man stepped in and took over the job of putting the car back together for me. It worked well, I paid the bills and he put the time in. He kept a VERY extensive thread going on the local Australian zed forum (35 pages and 42,000 page views attest to its enormity):
http://www.viczcar.com/forum/index.php/topic,6991.0.html
After 4 years and many times the budget and timeframe expected when I set out, I am honored to announce that the car is done. The photoshoot is complete and the car is ready to race.
1798875_622848217781206_527496445_n_zpsf
1688458_623225777743450_1389192397_n_zps
More interior and engine bay shots to follow, the photographer is still doing his final edits for the magazines, along with underbody photos.
The quick specs on the car:
Engine Bay:
Nissan L28
Triple 45mm Weber Carburetors
60 thou over bore
Polished, Ported and Port Matched Intake and Exhaust
Oversized Valves
F54 Block shaved below piston height
P90 Head shaved lots
Custom grind cam shaft
Lightened and balanced bottom end
MSD Digital series 6 ignition
MSD 6 blaster coil
9mm Ignition Leads
ATI Harmonic Balancer
Pointless distributor
Crow Cams double valve springs
Flat top pistons
Custom 2 1/2" Mandrel exhaust
Custom 6-2-1 equal length extractors
PWR Aluminium Radiator
Davies Craig dual 12†thermo fans
Nissan 300zx 70amp Alternator
Xenon HID H4 Headlights
ARP bolts and studs all through
Arizona Zed Car ally baffled sump
AZC lightened flywheel
AZC button clutch
Beta Motorsports dual non-boosted master cylinder kit
Driveline:
Nissan S14 5 speed gearbox
NISMO clutch pivot
NISMO 4.375 R200 diff gears with S15 viscous LSD centre
Wolf Creek Racing CV Joints
Suspension:
Adjustable height coil-over shock setup
Koni adjustable shocks
King custom springs
Techno Toy Tuning on-car adjustable front control arms
Techno Toy Tuning on-car adjustable Torsion/Compression Rod
Techno Toy Tuning Roll Centre Adjusters
Techno Toy Tuning on-car adjustable rear control arms
Custom Cro-Moly Tie-rods
22mm Front Swaybar
20mm Rear Swaybar
Complete Urethane Bushing set in all suspension components
Relocated Cross member front control arm pickup points
Brakes:
Front:
XR8 2 spot vented front brakes
DBA 4000 Rotors
Project Mu race pads
Rear:
Nissan R31 skyline single piston solid rotor rear brakes
DBA 4000 rotors
EBC Red race pads
Rolling Stock:
Track:
16x8 +4 Rota RB race wheels
Yokohama Advan 225/45/16 Semi-slicks
Street:
15x6.5 3-piece ultra light weight aluminium multispokes
14x5.5 Nissan 260z fully restored factory rims
Bodywork:
Ground-up full bare-metal restoration with all rust removed – 1300hrs
HSV Voodoo Blue metallic paint – 9 coats pearl, no base
Underbody sound deadening and heat-insulation
Custom Fiberglass front spoiler
Fiberglass BRE type rear wing
Headlight Covers
Fiberglass front and rear bumpers
Fiberglass Bonnet
Fiberglass Hatch with Acrylic window
Winding Acrylic driver and passenger windows
Holden GTS guard vents ‘gills’
Interior:
Sparco TEC driver and passenger seats
Momo Suede steering wheel
NISMO S15 solid shifter
NISMO Leather shift knob
Full Alcantara re-trim
Flocked trim pieces
3†6-point Race Harness
Retractable seatbelts
Acrylic winding windows
Redback Central Locking and Immobiliser
All original and working gauges, including clock
All new rubbers through-out
Stereo:
Triples Webers and 7500rpm
Awards and special thanks:
3rd in Production Sports 2009 Regularity Series
2:55 Lap at Bathurst, 245kph down Conrod. Fastest street-class z in 2008 and 2010
Numerous Speed Event Series, VSCC, WASCC, Corvette Club First in class and outright trophies
Big thanks to Dad for support in building and racing the car and an ultra-special thanks to Tus and the guys at Osborne Park Service Centre for looking after the car and building one cracker motor. Of course, this would not have been a successful project without the invaluable help of all our sponsors:
  •  Carline Mufflers Northbridge for a super exhaust system
  • John Fowler Automotivee for full suspension adjustment and alignment at/between events
  • John Whitfield Real Estate
Look, enjoy, comment.
Thanks,
Tom.
Edited by Whittie
Pharaoh, I knew someone would pick it! That was the catch can to get past scrutineering 2 weeks ago. The ally one is in now, but I don't have any new engine bay shots just yet.
Luseboy, I'm not quite sure what the conversion is. It's a Mitsubishi unit tho, if that makes a difference? The previous owner did that mod. The setup works very well tho, no trouble with it at all
