9/73-E31-260z Posted February 11, 2014 Share Posted February 11, 2014 So I had a thought:could you take the rear panel from a 240z (without the reverse light holes) and use it with just the tail lights from a 260z/280z, and then relocate the reverse lights? (say to the rear bumper or rear fogs or the like)I can't find anyone who has done this before, and I really like the look of the bar tail lights on the 260z and 280, I think it would look really good and very clean. Quote Link to comment Share on other sites More sharing options...
Vintage-TechZ Posted February 11, 2014 Share Posted February 11, 2014 On 2/11/2014 at 9:52 PM, 9/73-E31-260z said: So I had a thought: could you take the rear panel from a 240z (without the reverse light holes) and use it with just the tail lights from a 260z/280z, and then relocate the reverse lights? (say to the rear bumper or rear fogs or the like) I can't find anyone who has done this before, and I really like the look of the bar tail lights on the 260z and 280, I think it would look really good and very clean. I believe you'd need to swap the lights as well to pull that off as the surround window won't match the 260/280 lamp shapes. Even if you grind off the reverse lamp high area. The cars body hole may fit, you'd just need to test fit. Quote Link to comment Share on other sites More sharing options...
9/73-E31-260z Posted February 11, 2014 Author Share Posted February 11, 2014 Is there a difference in the shape of the lights? I thought they were the same dimensions just the 240 has the reverse lights. My 260z's tail lights even have an indent in the same spot where the reverse lights are on a 240's lights so it seems like maybe Nissan used the same mold for the plastic, so I had thought they were the same size, or at least very very close Quote Link to comment Share on other sites More sharing options...
rturbo 930 Posted February 12, 2014 Share Posted February 12, 2014 If I'm understanding right what you want to do, I think it would be easiest to remove the reverse light from the tail lights themselves, and fill in the opening in the 260z tail panel cover with fiberglass. Quote Link to comment Share on other sites More sharing options...
9/73-E31-260z Posted February 21, 2014 Author Share Posted February 21, 2014 Well the point was that it looked like I'd be able to use all factory parts and just move stuff around. If the other lights will fit the 240z panel I just might try it out later on, if not I don't need to go as far as fiberglass and all that, I just like to keep things simple. Quote Link to comment Share on other sites More sharing options...
morbias Posted February 21, 2014 Share Posted February 21, 2014 It's not possible, the 240z tail light cutout is a different length to the main tail light cluster on a 260/280z Quote Link to comment Share on other sites More sharing options...
9/73-E31-260z Posted February 21, 2014 Author Share Posted February 21, 2014 do you happen to know the dimensions on both? Like if I could just shave or cut a little out of the 240 panel to make the lights fit? Quote Link to comment Share on other sites More sharing options...
morbias Posted February 22, 2014 Share Posted February 22, 2014 (edited) I don't know the dimensions but that won't work as the 260/280z lights are not as wide as the 240z ones: Edited February 22, 2014 by morbias Quote Link to comment Share on other sites More sharing options...
