Rob L Posted February 14, 2014 Share Posted February 14, 2014 (edited) Hey guys kinda a newbie question here but is there a difference between front and rear camber plates on the s30? ....could I use an aftermarket bolt in front camber plate on the rear and vice versus ?.....or doss the front camber plate have more to it then the rear ? Thanks in Advance Rob Edited February 15, 2014 by theatriks Quote Link to comment Share on other sites More sharing options...
johnc Posted February 15, 2014 Share Posted February 15, 2014 The front camber plates need a bearing to allow the strut tube and spring to turn as you turn the steering wheel. Quote Link to comment Share on other sites More sharing options...
87pyro3 Posted March 2, 2014 Share Posted March 2, 2014 As far as camber plates. Are you referring to s 13 ( 240sx ) camber plates? Do they fit both front and rear? Have you already completed this? Pics and details.? Quote Link to comment Share on other sites More sharing options...
Rob L Posted March 2, 2014 Author Share Posted March 2, 2014 No I was referring to my 260z .....I was curious as to why the front set was more expensive then the rear . Quote Link to comment Share on other sites More sharing options...
Curtball Posted March 16, 2014 Share Posted March 16, 2014 As stated above the fronts just have a set of needle bearings in the for when you turn your, your front suspension does as well. The rear does not Quote Link to comment Share on other sites More sharing options...
