s30red240z Posted March 7, 2014 Share Posted March 7, 2014 Will i be able to use my factory engine hardware with MS? (Injectors, fuel rail, EGR vavle etc.) Yes will work, the only thing you have to do is change all connector plugs and clean it. megasquirt is very sensitive to electrical noise. Quote Link to comment Share on other sites More sharing options...
winstonusmc Posted March 9, 2014 Share Posted March 9, 2014 If i were to buy just the basic MS1 ECU, would i be able to enable spark later on with lets say a software upgrade, or does the MS1 ECU have to be specially equipped with certain hardware in order to control spark? it probably missing the components on the board. I am sure it wouldnt be too much more to have them just fully build the V3.0 board for you. If your on a super tight budget, you could learn to solder yourself and buil it. I built mine, wasnt too difficult. Soldering a circuit board isnt too hard, just buy an iron at the heat level for circuit boards and thinner solder. I was surprised what an MS1 costs in a kit ~160. I put together an MS3/MS3X for 450. Quote Link to comment Share on other sites More sharing options...
