Head Change Need Info
I have a 78 280Z L28 motor with the N42 head and I was wanting to know what head change would give me the most horsepower? and how much you think I could get the head for?
Keep your head and go to the junkyard to buy a ZX motor with flat tops. Then put your head on the flat top motor to boost compression to around 10:1. There is a junkyard in Leander (Cantwell's) that has several L series motors you could probably get cheap. Including one in like an '80 model car with an auto that looks to be in good shape. (Thought about getting it myself...)
  • 1 month later...
The N42 is an exellent head. I suggest that you port and polish the head or have it done,install a header and performance exaust, and to raise compression easily use a NISMO head gasket. It's only 0.6mm thick, but make sure the pistons DO NOT portrude past the deck.
