christopherszx Posted April 10, 2014 Share Posted April 10, 2014 Okay, my problem is that when starting my car it cranks and cranks and cranks till finally it sputters into life. When i drive my car for a while then shut it off then start it agian i get the same problem. I have a feeling it is a voltage issue because if I push start my car it starts quickly and normal. I have fought this problem for way to long, post anything that might help Quote Link to comment Share on other sites More sharing options...
NewZed Posted April 10, 2014 Share Posted April 10, 2014 Clean the connections to your EFI harness. And the ignition system. The ignition module might be failing also, with a weak spark, which would be weaker at low voltage during starting. Quote Link to comment Share on other sites More sharing options...
Phantom Posted May 19, 2014 Share Posted May 19, 2014 Check the voltage on your battery. If it's b 12 volts or lower you need to replace it. It should test 12.5-12.7 volts if it's healthy. Quote Link to comment Share on other sites More sharing options...
