Guest Anonymous Posted September 27, 2002 Share Posted September 27, 2002 Thinking about swapping a motor from a Turbo Z into my 81 280ZX. Is there a on-line guide of this being done? And what parts are needed to do this swap from start to finish? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 4, 2002 Share Posted November 4, 2002 I don't know about an online guide, but this is what you're gonna need.A COMPLETE turbo engine with distributor. The entire engine room harness with all the relays and not altered or butchered.A matching ECU and air flow meter. Ideally all the parte come from the same car. The engine will bolt right in but don't mix up the mounting brackets or it won't sit in the engine compartment properly.Don't forget the rubber boots on both sides of the air flow meter.Swap out the remaining parts but use extreme caution when changing the engine room harness.If you have any questions please ask. Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 4, 2002 Share Posted November 4, 2002 there should be some kind of guide for this, its getting to be a hotter and hotter swap, for a turbo swap i think the easiest way is to get a running car that looks like dung. distributor is matched to ecu, and possibly the afm, i would avoid the 81 with the crank sensor. also avoid 83 with p90a head, but hey then again for the right price id grab and 83 no problem. Quote Link to comment Share on other sites More sharing options...
Guest pintoz Posted November 4, 2002 Share Posted November 4, 2002 Ok.....If I should avoid a 83 280zx with a P90A head, what kind of problems am I going to have trying to get 350HP+ from my motor? Quote Link to comment Share on other sites More sharing options...
Scottie-GNZ Posted November 4, 2002 Share Posted November 4, 2002 Drax has a great site but my link to it does not work anymore. Maybe he can chime in. Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted November 4, 2002 Share Posted November 4, 2002 As far as I know there are no real problems with the P90A, except if you have a lifter fail - they are hard to find. Don't be dismayed if you do have a P90A, only some of them had hydraulic pivots. Quote Link to comment Share on other sites More sharing options...
