RB26 with RB25 trans clutch question
05plsrt4
I'm in the market for a clutch for my build but am having a hard time figuring out which clutch I need for my combo. Most of the dealers cant give me a straight answer other than "it should work" as long as it is the same type (push or pull) What I don't understand is that the RB26 clutches are all different part numbers than the RB25's.
After searching, it seems like most people here are using Z32 transmissions. I'm using a RB25det trans.
Do I need an RB26 clutch or an RB25 clutch?
You'll want to use a clutch that matches your transmission.
If you're using a R33 RB25DET transmission you'll need a push-type:
http://www.rawbrokerage.com/spec-super-twin-clutch-rb20-rb25-rb26-push-type/
If you're using a R34 RB25DET NEO transmission you'll need a pull-type:
http://www.rawbrokerage.com/spec-super-twin-clutch-rb25-rb26-pull-type/
Hope that helps!  Let me know if you need something sent your way.
