Len Posted November 15, 2002 Share Posted November 15, 2002 Quick questions; Is the 240SX TPS plug identical to allow a person to plug in the 280ZXT female connector into 240sx with no mods? Also is the 240sx TBS plug; facing 90 dgrees left tward the direction air intake on TB? As compared to a 45 degree angle to the right from up? Quote Link to comment Share on other sites More sharing options...
turbobluestreak Posted November 16, 2002 Share Posted November 16, 2002 I know that it plugs right in and that if you use the 240sx t/b it will work but not on a 280zx t/b because of mounting differencs I have on in my car and it works fine. I am running the 300zx t/b but want the 240 t/b. tbs Quote Link to comment Share on other sites More sharing options...
Len Posted November 17, 2002 Author Share Posted November 17, 2002 Thanks for the reply Turbobluestreak . Since the TPS plug portion on the 240sx TB is positioned horizontal to TB with plug in direction of air intake. I will need to clip my existing plug and add a few inches of lenght so it will be long enough to directly plug in. Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 17, 2002 Share Posted November 17, 2002 Len - you don't need to clip the plug. Just separate the two TPS harness wires from the factory shrink wrap and it will give you quite a bit of slack. I am also running the 240SX TB and TPS on my car. Regards - Yasin Quote Link to comment Share on other sites More sharing options...
Len Posted November 18, 2002 Author Share Posted November 18, 2002 Yasin After reading your reply. Looked and saw my three grounds mounted on my intake from the same wiring harness the TPS female plug was situated. They weren't allowing the lenght needed to connect the plug. By golly your right! I cut back some of the shrink wrap. relocated the three grounds all together on bolt closest to TPS and wala. Thank you for your insight. Dang sometimes I get so caught up in things, I don't see it when its stareing me in the face!!!!!!!!!!!!!! Quote Link to comment Share on other sites More sharing options...
slownrusty Posted November 18, 2002 Share Posted November 18, 2002 Glad I was able to help! Regards - Yasin Quote Link to comment Share on other sites More sharing options...
