76Fairlady Posted May 29, 2014 Share Posted May 29, 2014 I picked up a nice set of rewinds for a GOOD deal, only problem is that they are the 4x110 bolt pattern with a +20 offset. 15"x7". Now I have come across a really nice wheel adapter manufacturer to allow these 4x110's to mount on the Datsun 4x113.5's. They are 1" thick as well. Would this setup clear and have enough room for the Arizona Z Car big brake kit with the 4 piston Wilwoods?? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
G-E Posted May 29, 2014 Share Posted May 29, 2014 Well your new wheels would have a minimum of 1" spacing from the rotor hat, plus whatever the wheel already had to the spokes, it's a good possibility they will clear... Your new offset would be -5 Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 29, 2014 Author Share Posted May 29, 2014 Yes. -5.4 Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 29, 2014 Author Share Posted May 29, 2014 I was reading that the AZC big brake kit will clear some 15" wheels.. Just wanted to make sure these would work before I went out and bought the $140 adapters! Lol Quote Link to comment Share on other sites More sharing options...
G-E Posted May 29, 2014 Share Posted May 29, 2014 You bought wheels that didn't fit recklessly, why stop there? Quote Link to comment Share on other sites More sharing options...
Nv_s30 Posted May 29, 2014 Share Posted May 29, 2014 I have the Atara racing 15x10.5 wheels and I did a test fit and they fit very close fit but they fit non the less lol Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 29, 2014 Author Share Posted May 29, 2014 No, I bought them on purpose because they were a great deal! I could sell them and easily double my money but if it only takes $140 for adapters and they'll clear tue AZC brake kit, then they're going on the Z! Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted May 29, 2014 Share Posted May 29, 2014 PM me with your backspacing measurement. I have 4-pot AZC brakes and am running 15" wheels with 1" spacers. But I speak backspacing, not offset. If you wanted to, you could send a wheel to me and I can test fit it. Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 30, 2014 Author Share Posted May 30, 2014 I'll measure them after work. Thanks! Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 30, 2014 Author Share Posted May 30, 2014 Ok, online sources says it is 4.7". My measurements say 4.8125". Let me know what ya think! Thanks! Quote Link to comment Share on other sites More sharing options...
kyle319 Posted May 30, 2014 Share Posted May 30, 2014 Id be willing to sell you the correct size ones if you end up changing your mind:) If not best of luck with the adapters! Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 30, 2014 Author Share Posted May 30, 2014 Id be willing to sell you the correct size ones if you end up changing your mind:) If not best of luck with the adapters! Which ones are those? 15x7, 4x114.3 lug patterns, with 0 offset? Or 16"s?? Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted May 30, 2014 Share Posted May 30, 2014 (edited) My wheels are 5.5" backspacing (which clears the caliper). If I use the 1"spacer, that makes them 4.5" adapted back spacing (which clears the fender lip). Not looking good for you. With a spacer you are at 3.7 or 3.8" adapted backspacing, which means that your wheel will hang outside the fender by about an inch. You willing to flare (a big job just to use wheels that don't fit)? Edited May 30, 2014 by RebekahsZ Quote Link to comment Share on other sites More sharing options...
RebekahsZ Posted May 30, 2014 Share Posted May 30, 2014 Get a 16" zero offset 16x7 and all these fitment issues go away. Quote Link to comment Share on other sites More sharing options...
76Fairlady Posted May 30, 2014 Author Share Posted May 30, 2014 I'm actually looking to flare the car all around, but I'll prob her some 16's to do that with. Thanks! Quote Link to comment Share on other sites More sharing options...
