Synlubes Posted December 18, 2002 Share Posted December 18, 2002 Ok, the P-90A is a hydro lifter head and the P-90 is ajustabe(non-hydro)! Now, does the P-90 head have the same oil passages(that feed the hydro lifers) cast into them as does the the P-90A? I know the whole size is different where the "lifters" go! Thats not what this ? is about! Hope this makes sence!!! I have a P-90A that i was going to have threaded selves made to be able to install ajustable rocker pivits, but have a concern about the oil supply wholes that feeds the hydro lifters! Any info would be helpful! If the P-90 does not have the oil feed wholes I would like to go with it instead the P-90A! Quote Link to comment Share on other sites More sharing options...
280Zone Posted December 19, 2002 Share Posted December 19, 2002 Doug, I am not sure if I can help with your question much but don't forget, not all of the P90A heads have hydraulics. Quote Link to comment Share on other sites More sharing options...
Synlubes Posted December 19, 2002 Author Share Posted December 19, 2002 Ok, thanks I did not know that! So, maybe they are from the same casting and some are drilled for hydro lifters and some are drilled for ajustable pivits??? Again, my concern is with the pressurized oil feed under the installed selves and ajustable pivits! Any other wisdom out there! Quote Link to comment Share on other sites More sharing options...
Z-Gad Posted December 19, 2002 Share Posted December 19, 2002 I had mechanical lifter bosses made a few months ago with the correct size to fit the P90A hole. They worked fine w/o any problems. Quote Link to comment Share on other sites More sharing options...
Len Posted December 19, 2002 Share Posted December 19, 2002 What did it it cost you Z-gad to have that done? Did they fit in the original rocker arms? I figure they drilled pivots for oil port? Quote Link to comment Share on other sites More sharing options...
