ScottyK Posted August 25, 2014 Share Posted August 25, 2014 (edited) .. Edited September 6, 2014 by ScottyK Quote Link to comment Share on other sites More sharing options...
ScottyK Posted August 25, 2014 Author Share Posted August 25, 2014 (edited) .. Edited September 6, 2014 by ScottyK Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 25, 2014 Share Posted August 25, 2014 You have the car, why don't you measure it instead? Quote Link to comment Share on other sites More sharing options...
ScottyK Posted August 26, 2014 Author Share Posted August 26, 2014 (edited) .. Edited September 6, 2014 by ScottyK Quote Link to comment Share on other sites More sharing options...
beermanpete Posted August 26, 2014 Share Posted August 26, 2014 73 mm Quote Link to comment Share on other sites More sharing options...
whatnow123 Posted August 26, 2014 Share Posted August 26, 2014 They are 73mm.Nice find on that car by the way. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 26, 2014 Share Posted August 26, 2014 The center bore size varies. These cars a lug centric so Nissan wasn't concerned with a exact, machined hub center. If you look there is a radius that will interfere with a tight fitting wheel centerbore so be careful. Quote Link to comment Share on other sites More sharing options...
johnc Posted August 26, 2014 Share Posted August 26, 2014 Quote Because I don't have time. I work, a lot. And this isn't a good answer here. Quote Link to comment Share on other sites More sharing options...
ScottyK Posted August 28, 2014 Author Share Posted August 28, 2014 On 8/26/2014 at 5:29 AM, beermanpete said: 73 mm On 8/26/2014 at 2:23 PM, whatnow123 said: They are 73mm. Nice find on that car by the way. On 8/26/2014 at 3:27 PM, johnc said: The center bore size varies. These cars a lug centric so Nissan wasn't concerned with a exact, machined hub center. If you look there is a radius that will interfere with a tight fitting wheel centerbore so be careful. Thank you very much. Quote Link to comment Share on other sites More sharing options...
ScottyK Posted August 28, 2014 Author Share Posted August 28, 2014 (edited) .. Edited September 6, 2014 by ScottyK Quote Link to comment Share on other sites More sharing options...
