heavyweight280 Posted August 27, 2014 Share Posted August 27, 2014 like title says, I want the set of resitors that go under the distributor. Unfortunately I dont have a pic to show what I mean. Apparently, whoever had my car before me never put them on the car, and I want them to try and sort out some electrical isues I am having. I could also use the entire ground harness that connects to negative battery cable. Thx Quote Link to comment Share on other sites More sharing options...
tyler031734 Posted August 27, 2014 Share Posted August 27, 2014 What your describing in part sounds like the resistor that cut your 12v down to 6v for there 6v electronic ignition. 75-78 280z Check to see if someone put the better 280zx distributor on there. That would remove the resistor. Quote Link to comment Share on other sites More sharing options...
NewZed Posted August 27, 2014 Share Posted August 27, 2014 (edited) There is no set of resistors under the distributor. Check the Electrical Chapter of the FSM to see what you might be thinking of. http://www.nicoclub.com/FSM/280z/ Edit - tylernumber, Nissan removed the ballast for 1978. Edited August 27, 2014 by NewZed Quote Link to comment Share on other sites More sharing options...
88dangerdan Posted August 27, 2014 Share Posted August 27, 2014 I just took these pictures. I don't see any resistor. they're from my '77 280z parts car. But I probably have the other part you're looking for Quote Link to comment Share on other sites More sharing options...
