L28ET rebuild/head gaskets
CU Zcar
I'm soon going to pull an L28ET out of an '83 280ZXT to rebuild. I did a quick search about head gaskets since I considered using a metal head gasket (though don't plan on it since I don't think my goals & sticking with stock turbo merit getting one) but ran across some posts saying the Fel-Pro L6 head gasket lacks a passage and causes coolant leaks. You're telling me they don't make an L28ET gasket? That's too bad, I'm generally pleased with Fel-Pro gaskets. Besides stock Nissan gaskets and the Nismo or HKS metal head gaskets, what other brands will work?
Also, I have a set of piston rings sitting around unused from my last rebuild, they're for an 83 N/A 280ZX, are they any different from Turbo rings?
Lastly, are any of the rebuild sets with all the parts bundled together worth anything?
If you can stick with the Nissan head gasket, the Fel-pro is known to fail. Mine blew and caused exhaust to get into the coolant. Do it right and save yourself the hassle of having to do it again.
