kyle319 Posted November 21, 2014 Share Posted November 21, 2014 Is anyone here running Megasquirt on their 2j? Im in the process of swapping out my l28 which is currently on ms and I would love to keep the wiring I have (or at least as much as I can). If your running ms and the 2jz could you share the details of your swap and maybe post up a basic msq? Quote Link to comment Share on other sites More sharing options...
Ryan Merrill Posted November 21, 2014 Share Posted November 21, 2014 I dont have any experience with Megasquirt. The factory harness is preyy easy to get up and running from my undertanding. To start that the route I will be taking. Quote Link to comment Share on other sites More sharing options...
dexter72 Posted November 22, 2014 Share Posted November 22, 2014 I will be doing this swap soon, Mine is with a 2JZGE Engine and adding a turbo to it. Your Megasquirt options that i know of: Megasquirt 2 is setup to read a 36-1 wheel out of the box. So i am going to use a 36-1 crank trigger wheel bolted to my crank pulley/harmonic balancer. sensor, Ford EDIS 6 box and ford coil pack. I dont want to solder anything into my Megasquirt box, its been working great for 7 years, no need to mess it up. You can solder coil drivers and or ignitors into your megasquirt box and then download the latest firmware to get you going for a coil on plug setup. Ms3 will read everything, all the 2JZG Distributor and 2JZGTE cam/crank sensors, i think they are 24-1 or 24-2 Hope that helps you out. Also join clublexus. Browse the SC300/400 performance section tons of info to help us out. I have been reviewing posts for a few months now. Quote Link to comment Share on other sites More sharing options...
motomanmike Posted November 22, 2014 Share Posted November 22, 2014 (edited) DIYautotune also released a few new PNP ecu's for the 2JZ. If you have all of the toyota harness it should be fairly simple wiring if you went that route. "MegaSquirtPNP Pro is here! Our latest release is based on the MS3-Pro and fits the '93-98 Toyota Supra Turbo. Other MegaSquirt PNP models include:" http://www.diyautotune.com/catalog/megasquirtpnp-pro-jz9298-for-the-9398-toyota-supra-manual-trans-p-591.html Edited November 22, 2014 by motomanmike Quote Link to comment Share on other sites More sharing options...
Matt Cramer Posted December 17, 2014 Share Posted December 17, 2014 And we have the MSPNP base map online as well: http://www.megasquirtpnp.com/mspnpp_maps.php The MSPNP ships with this, of course, but it can be useful for getting a head start on a wire-in installation. We're also running a 2JZ in a 240SX with a wire in harness and MS3-Pro. Quote Link to comment Share on other sites More sharing options...
devil280Z Posted December 19, 2014 Share Posted December 19, 2014 I have the ms3 pro for my 1jz vvti, have yet to get everything running though. Been busy with other stuff. Quote Link to comment Share on other sites More sharing options...
kyle319 Posted December 20, 2014 Author Share Posted December 20, 2014 Good information everybody! Does anyone know where you can source gte pistons and rods? I heard titan had them brand new for 300 bones but I couldnt find them.. and thanks for pointing me towards the base map matt, Ive seen that 240 dyno vid and she ran pretty good! Id love to swap the 2j into my datsun sometime this upcoming year but I gotta get her in road worthy condition first and hopefully by then someone with have the mount situation figured out! Quote Link to comment Share on other sites More sharing options...
oatmilk Posted December 29, 2014 Share Posted December 29, 2014 Im going with the MS3 Pro Plug and Play. Should be up and running by the end of February 2015. Quote Link to comment Share on other sites More sharing options...
