Replacment for stock temp sender
How about one of these?  There are many other sources out there, but here's a couple I've done business with in the past and never had a complaint.  A used unit should work fine also, if you don't feel like buying a new part....sensors can be easily tested in a pot of hot water using a separate thermometer to check your sensor readings.
http://www.jagsthatrun.com/Pages/Parts_DATZ_Wat-Temp-Send.html
http://www.thezstore.com/page/TZS/PROD/10-1878
http://www.thezstore.com/page/TZS/PROD/16-7110ki
http://www.zcarsource.com/
http://www.datsunstore.com/sensor-water-temp-7579-p-1400.html
Does it fit a V8 Intake and work with the stock gauge?
I bought a stock temp sender and went to the hardware store and found a 1/2 NPT that was wide enough in the center for the sensor to fit into.  Then I JB Welded all around it.  Looks great and works like a champ.
