R200 driveshaft flange differences
TeemuM
I am using short nose R200 differential originally from Infiniti G37 automatic. Diff has 3 bolt flange that is meant for rubber joint. However I am using U-joint, so I need round flange or flange that has enough material so it can be modified.
pera1.jpg?img=smaller
Every other R200 has round flange, so does anyone know if those short nose R200 flanges are interchangeable?
Edited by RB26powered74zcar
  • 3 weeks later...
I know I had at least 1 R200 with a square flange. I think it was an '85 12mm from a turbo car. I swapped a '78 flange from the 10mm I had in the car when I put the precison gear LSD in. Both of those are Long nose however, so not sure if that helps you or not.
Edited by Mike C
