bahelion89 Posted January 16, 2015 Share Posted January 16, 2015 i'm seeing alternators on the drivers side of the l28 engine and i'm curious if its just a simple bracket swap or more complex? I would like to use the bolt holes in the block from the alternator for a different bracket im making.... Thank you! Quote Link to comment Share on other sites More sharing options...
z240 Posted January 16, 2015 Share Posted January 16, 2015 (edited) Nothing moves directly. Nothing in common left to right side other than the paint, and maybe some grease. There are four lovely 10 x 1.5 mounting holes in a nice squarish pattern on the drivers side that was for the air pump or later A/C bracket. Since you're having to build a bracket from scratch, nows the time to build a bracket to use a nice big amp GM 1 wire alternator. Edited January 16, 2015 by z240 Quote Link to comment Share on other sites More sharing options...
Tony D Posted January 17, 2015 Share Posted January 17, 2015 (edited) Since the LD28 Alternator mounts in that side...I'd be wary of saying no brackets exist, or that make it difficult. http://s348.photobucket.com/user/windsock_on_the_hill/media/Timingmarks012small.jpg.html I don't know WHY you would want the alternator under the exhaust header soaking up all that heat, but grab some LDBrackets and have at it. Edited January 17, 2015 by Tony D Quote Link to comment Share on other sites More sharing options...
