Guest Anonymous Posted August 28, 2001 Share Posted August 28, 2001 that2ksguy: the 5speed tranny's in the NA and TT are different. Different gears and supposedly the TT version can take a lot more abuse, i have no clue why. guys...I have some disheartening news about the diff from my yard. They cost 500 a pop. I'll go check this other yard i know i could get it for much less, but how much? we'll see.. Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted August 28, 2001 Share Posted August 28, 2001 Thank you for chekcing into this, I appreciate it! $500 is a bit steep right now for a project I might not need and is a long term project. If nothing you're giving us a good idea as to what they go for in general. Going to have to search here and see what ratios there are avalable. At least there are no clutches in them to replace. I can confirm that my LSD catches posi though Quote Link to comment Share on other sites More sharing options...
Mike C Posted August 28, 2001 Share Posted August 28, 2001 Found this and thought it might apply... twin turbo nissan v8 Quote Link to comment Share on other sites More sharing options...
Owen Posted August 28, 2001 Share Posted August 28, 2001 Apply to a CART car! That thing is sweet! Like those exhaust manifolds? Owen Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted August 31, 2001 Share Posted August 31, 2001 hey Owen, did you ever find that Autoworks magazine that had the turbo Q45 engined Z? What about anyone else? any more progress or ideas? I'm still up in the air deciding to go w/ my current combo or the Q45 setup... i hate to go sbc just b/c i like to be different... and this swap is definately not that Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 1, 2001 Share Posted September 1, 2001 I finally stopped by the other yard. They wanted to $410 for the diff but I would have to take it off myself Here's an odd thought though. I realized that the positioning and size of the Active Suspension Q45 and my Z are "somewhat" similar. Here's a neat story: a buddy of mine succesfully grafted the older maxima's sonar/electric suspension system into a 200sx. Barring any extreme differences in suspension geometry between the Q and Z, I wouldn't see why with a lot of determination and possibly money, this couldn't work. The Q's active suspension system is operated by "real-time" calculations. The g and yaw sensors feed the control unit information every 10 milliseconds or so and then the system adjusts it's position accordingly to maintain a flat smooth ride. it's kinda cool because when I drive my Q, I sometimes take turns at really highspeeds to see if I can upset the suspension, but it never works. Body roll is there, but is minimal compared to a regular car. I'll take a look at the struts, valves and pumps a lil more closely to see if this is doable... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 1, 2001 Share Posted September 1, 2001 Welll, maybe the later ZX diffs aren't much cheaper than the LSD clutch units If someone does a kit for them the $400+ won't be so hateful though UMO... Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 2, 2001 Share Posted September 2, 2001 Wait, didn't the TT 300ZX have the same differential as the Q45? Aren't they both R230's? If the 300Z TT version does have the R230 diff then I'm sure the infiniti J30 also has the R230. Cool thing is, even though it shares the same engine as the 300ZX it's a grand cheaper. I wonder if that also applies to diffs? I'll add this to my "Things-to-look-up" list. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 4, 2001 Share Posted September 4, 2001 that1ksguy: Good news. i was scanning through the net for old Q engines and found one near your area, i guess. It's in Arkansas. Not sure how far it is but here's the number to the place: (800) 662-6150. The name of the place is AA Auto. They're offering it for only $800. Hope this helps. Quote Link to comment Share on other sites More sharing options...
Guest Badzx Posted September 4, 2001 Share Posted September 4, 2001 got motor for free, needs chain guides of coarse. Pick it up in return for some computer work. I've located a 94 300tt that had been wreck, with a complete drive train w/R230. I believe the R230 are the same except for the rear cover. Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted September 4, 2001 Share Posted September 4, 2001 sopdadope: thanx for the info.. i'll be calling them in the morning when i get to work... hmmm i'm thinking road trip to AR this weekend.. hope they're open on Saturdays. Depending on what part of the state they're in it'll be a 3-5hr drive probably.. not bad. For those of you who don't know my city (Olathe) is part of the KC metro area... just another wonderful suburb (they love it when i run air tools in the garage) I guess it's only fitting the engine come from AR since the Z did too... gotta love a state that doesn't use salt on the roads. Anyway i think i have a TT 5spd found the only reason i can think of it wouldn't bolt up is if the engine crank doesn't have a hold drilled in it for the tranny's main shaft? Badzx you're probably the only one of us who knows at this point, any insights? Thanks Guys Quote Link to comment Share on other sites More sharing options...
Guest Tht1KSguy Posted September 4, 2001 Share Posted September 4, 2001 hey sopdadope you didn't happen to hold onto that link to that motor did u? I called the guy this morning and he's telling me $1265 + freight over the phone which isn't much better than i can get one here in KC for plus i can hear it run who knows... i'll see what i can dig up Ryan Quote Link to comment Share on other sites More sharing options...
DavyZ Posted September 4, 2001 Share Posted September 4, 2001 BLKMGK: the motor looks pretty good stock, and has wide heads not totally unlike the 4.6 Ford. I'll see if I can get one of the guys to take a digital pic of the engine at the meet in San Leandro this Saturday Davy Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 5, 2001 Share Posted September 5, 2001 I cannot wait to hear how thisthese swaps turn out! Please document the heck out of them and keep us posted. This just sounds like one really neat swap and if it runs well could be a good alternative to the normal American V8s. What's this motor look like bare? Will headers be an issue or can stock manifolds be used? Hope the shifter ends up in the right place Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 6, 2001 Share Posted September 6, 2001 Here are pics I took of my engine, enjoy! Quote Link to comment Share on other sites More sharing options...
Owen Posted September 6, 2001 Share Posted September 6, 2001 Ummmm. they're not showing, at least not on my computer. Do you have a link to a page they're posted at, like a photo album or something? Owen Quote Link to comment Share on other sites More sharing options...
Owen Posted September 6, 2001 Share Posted September 6, 2001 Thanks, was able to view them fine after that. I thought I knew the answer to your question but now you got me thinking...it is a rear wheel drive though...the driveshaft I got from a Q45 was in 2 pieces and long as hell! Owen Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 7, 2001 Share Posted September 7, 2001 sorry about the pics not showing up in the post. Apparently it seems photopoint is now charging a fee linking the pics... Blackmgk, i don't blame you. First time I saw the motor I thought it was FWD too. The arrangement of the runners looks as though the motor is mounted horizontally. Yes it is a very short motor, but wide. According to my calculations, the engine will have a VERY narrow clearance in the Z engine bay, actually about two inches, give or take. cool thing though is that from the looks of the intake plenum that it could be fitted pretty far back against the firewall without needing to tamper with the brake lines and modifying the hood latch. The VH45DE block is sitting in a bag in my garage right now and it with a little engine degreaser, looks brand spankin new. Pretty light too, I picked up and moved it around without with my bare hands... Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted September 7, 2001 Share Posted September 7, 2001 Weird, I check it through this ISP and it comes up fine - did you change anything? Wow, 2 inches is cutting things pretty close. Is that 2 per side or total? Leaves very little room for error but if you've got a block there then a test fit shouldn't be too hard to try If you get to that point please try to take some pics. How is the motor mounted? Is it conventional sorts of mounts or something funkier? Does it look like it'll be easy to mount? Do we have any word on the transmission out of a TT yet? Would really suck if someone got one only to find out it was a no-go It may not be the fastest when you're done but it's going to be unique and darned nice! Thanks for keeping us up to daye. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted September 7, 2001 Share Posted September 7, 2001 That's odd, I didn't touch a thing...The internet works in mysterious ways...yes that's 2 inches per side. I wish I could've had it down to the exact millimeter, but all I had was a tape measure. A buddy of mine, had his Q dynod and the specs read: 248 lb/ft. @ 4300 rpm and 247 hp at 6,300 rpm, roughly. I figure with that huge driveshaft the drivetrain losses figures to be around 14-17%. This is with the stillen exhaust alone. About how much power do you really think it's producing? Another interesting question: I know of a guy around my area who has an LT-1 and T56 swap in his 73 Z, haven't seen him, but heard of him. Who do you think would win in a stoplight 1/4 mile? The bone stock LT-1 Z or a plain jane VH45DE Z? Quote Link to comment Share on other sites More sharing options...
