Hello Today I will be posting about my project that I am currently working on at the moment. The car is a
1983 280zx Turbo, I will be attempting to put a engine from a 1985 302 ford mustang 5.0L & transmission in the Z,
The engine is upgraded with a Holley 850 double pumper & I also am going to try to save the turbo off the 280zx engine and adapt it with a mod if I can.
A few rough steps that ill be working on will be consistent of :
1. Rebuilding my 302 engine with a kit I found.
2. Rebuilding my transmission with another kit I found.
3. Gutting a ripping out everything in the engine bay that I don't need.
4. removing old transmission.
5. removing old electric fuel pump
6. Removing old exhaust system & replace single with double (Not sure where to get it from tho)
7. Installing new fuel pump & regulator
8. Figuring out where the mounts need to go to hold the transmission
9. welding new mounts for transmission
10. Figuring out where the mounts need to go to hold the V8 engine
11. welding the new mounts on for the engine
12. Replace old shocks with new ones (Before the heavy engine & transmission is mounted)
13. replacing old brake pads with new ones
14. Sanding down body and engine bay (Getting it ready for new paint job)
15. Painting the body with a new paint job
16. removing & Installing new ECU that will control the 302
17. Installing rebuilt Transmission and bolting to new welded mounts
18. Lowering V8 302 engine into the car and bolting it into place to newly welded engine mounts
19. reconnect ecu and other wires needed
20. connect the new fuel line
21. connecting the ignition
 "Please feel free to comment what I might need to add to my to do list to complete my project "
Links to Items I will be using:
302 Engine Rebuild Kit: http://www.summitracing.com/parts/fem-mhp178-302?seid=srese1&gclid=Cj0KEQiA1NWnBRDchObfnYrbo78BEiQA-2jqBUjyJhOLMnCqN4NMGLEr2bjhQn9i7kBmPbNI3CBWxWIaAiyg8P8HAQ
Transmission Rebuild Kit: http://www.latemodelrestoration.com/item/M7000A/85-95-Mustang-T-5-Transmission-Rebuild-Kit?utm_source=google-shopping&utm_medium=comparison-shopping&utm_campaign=google-shopping-v2&year=1985&gclid=CjwKEAiAmuCnBRCLj4D7nMWqp1USJABcT4df9mLC_ISJ7PxdA8gdHsRBMAyRk6l_G6zYk2gEkzD6JxoCCCDw_wcB
ECU: http://www.automotix.net/usedautoparts/1985-ford-mustang-engine_computer-product-3ts94547.html?gclid=Cj0KEQiA99qnBRDnrYCkt4ClzZABEiQAvqPaLESGks6klkmeMEu3_ErFIQ4is-zsAQdBmxxwSbAAuecaAmCA8P8HAQ
Fuel Injector Kit: http://www.buyautoparts.com/plabuynow.asp?year=1985&make=Ford&model=Mustang&partname=Fuel_Injector_Set&partno=35-81164_8I&gclid=Cj0KEQiA99qnBRDnrYCkt4ClzZABEiQAvqPaLLdqEwOW2UaSH7uPrKDU5p1DGYQ_Pdiu9Hz9dR7_vuUaAkYJ8P8HAQ
Fuel Pump: http://www.summitracing.com/parts/hly-12-801-1
Fuel regulator: http://www.protuninglab.com/al0psiadhifu3.html?utm_source=googlepepla&utm_medium=adwords&id=56128534817
Shocks: http://www.ebay.com/itm/Datsun-280ZX-Turbo-1979-83-KYB-Rear-Gas-Shocks-Struts-NEW-Pair-/221706118466?pt=Motors_Car_Truck_Parts_Accessories&hash=item339eb6e542&vxp=mtr
Brakes: http://www.cquence.net/nissan-280zx-1983-performance-series-dimpled-slotted-brake-rotors.html?gclid=Cj0KEQiA99qnBRDnrYCkt4ClzZABEiQAvqPaLHWZVqyk-Aggqem_mdyJNkvVsasAiT0fX8xkxefOhAYaAqef8P8HAQ
Clutch: The 280zx has a stage 3 clutch and i'm not sure if I can use it on the 302 but id like to.
Electronic Distributor:
http://www.americanmuscle.com/distributor-7985.html?utm_content=Restoration+-+Engine%7CAM+Restoration&utm_campaign=79-04%20Years&utm_source=Google-pla&utm_medium=Shopping&utm_term=&AMID=distributor-7985-GSBasicFitmentV1&year=1985
Alternator:
http://www.americanmuscle.com/paperformance-95amp-alternator-polished-8793.html
Any parts I may have missed please feel free to comment it, for any haters out there this is my first swap like this so please keep your hating comments to yourself, Thank you.
Hello, and welcome to HybridZ.  Sounds like a great project, but you will get better results if you post your thread in this sub-forum (for Ford V8 swaps):
http://forums.hybridz.org/forum/15-ford-v8z-tech-board/
You are currently posted in the Gen 1 & II Chevy sub-forum.
Good luck with your build and keep the updates coming!
This topic is now closed to further replies.
