Looking for stock L28e map
WellThatsSurprising
Before you say it, yes I already checked the map info sharing thread in the FAQ. The only one that matches what I need was posted in 2006 and has long since 404d.
Anyways I've got a MS1 V2.2 board running fuel only, hoping somebody has a decent map to save me a little bit of time. Bone stock L28e out of an 81ZX, Innovate LC-2 wideband, GM temp/IAT sensors, and the 240SX TPS.
If you have the engine running, start driving it and use the wideband to help you tune it. Lean it out for highway cruises. Fill up the tank and enjoy learning about tuning your engine. Once i got my engine to run, I had a lot of fun tuning it. Then a friend of mine made map changes on the laptop, as i was driving it. Really fun first weekend tuning it.
Nowhere to do a screen shot of what I started with. Have you gone to DIY Autotune for their mapping images of various setups?
Mine ran out the box on the fueling map for a 383 Stroker after changing the defaults from "8" to "6" Cylinders.
Rich, but it was driveable.
Restating the obvious in my mind, but ANY map from an L28ET is going to work...put one in for what you can find.
Worst case if they are HP, is you're rich. It's a similar curve, you just click-drag, shift arrow down down down to lean it out a whole series of cels at a time. Not really difficult and fast.
