blacice Posted April 10, 2015 Share Posted April 10, 2015 Hi everyone, new to the forum and new to turbocharging, very new. I would like some help if someone can offer up in identifying a Grrett turbocharger for me. Here is the turbo info: Garrett Honeywell KTT2 M33 INTAKE: A/R .72 EXHAUST: A/R 1.22 GAG P/N: 710223-0001 S/N: KD 00143 K And my measurements: MEASUREMENTS: Intake Side: 90mm / 61mm Exhaust Side: 81mm / 68mm Quote Link to comment Share on other sites More sharing options...
mtnickel Posted April 10, 2015 Share Posted April 10, 2015 (edited) Can't tell you exactly what it is. The compressor is a lower trim BIG wheel. Similar to a GT35r but with an even bigger exducer (meaning probably more intended for higher pressure ratios (read Boost levels). HP supports probably between 400-600hp (based on wheel size/trim alone. Design of wheel could greatly affect this number). It has a BIG Exhaust housing however so will probably not spool well on a smaller gas engine. If i had to guess, it's a diesel based turbo meant for a big (7L ish) engine. Maybe ask instead if it would be ideal for your application, not just "identify it". Unless of course you are just trying to sell it. Regards,Mark Edited April 10, 2015 by mtnickel Quote Link to comment Share on other sites More sharing options...
blacice Posted April 10, 2015 Author Share Posted April 10, 2015 Thanks Mark. I already figured it was to big for my application, however I was trying to get info on it and then see if there was a way to get a smaller exhaust housing to where it would work for me. Just curious. I know some guys run that size on the RB motors but with a smaller exhaust housing/ smaller compressor. I'm just seeing what my options are for the future as I already have a T28 lined up for my KA. Quote Link to comment Share on other sites More sharing options...
mtnickel Posted April 10, 2015 Share Posted April 10, 2015 I was close. Further research on the model number you gave resulted in this: Engine, Valves, Horsepower, CC (18.6L engine), and turbo model DS2840LE 10V 700 18600 TA45 710223-0001 It's a BIG turbo. Probably wouldn't spool till over 5000rpm on a 3L. Might do OK on a big v8 Quote Link to comment Share on other sites More sharing options...
mtnickel Posted April 10, 2015 Share Posted April 10, 2015 On 4/10/2015 at 10:09 PM, mtnickel said: I was close. Further research on the model number you gave resulted in this: Engine, Valves, Horsepower, CC (18.6L engine), and turbo modelDS2840LE 10V 700 18600 TA45 710223-0001 It's a BIG turbo. Probably wouldn't spool till over 5000rpm on a 3L. Might do OK on a big v8 Just find info on a TA45 for more details. Quote Link to comment Share on other sites More sharing options...
