L28et Wire Harness Question
So I'm in the process of swapping an l28et from a 1981 280zx into my 1978 280z. I'm just confused on what these plugs are and if they are even important. Also, if someone knows if these two ring terminals go or if they are just a ground that can go anywhere. Last questions, is the plug following after the two ring connectes. Would help a lot. Thanks.post-48298-0-56717400-1428891760_thumb.jpgpost-48298-0-25742900-1428891905_thumb.jpg
On the last picture, does it matter where the ground in the back goes?
Looks like the ground wire to the AFM to me.
Your other ground wire - the one with the 2 ring terminals - Large ring to the body (fenderwell), small ring to the intake manifold.
Your picture is so bad, I'd have to go to my cabinet in the back of the shop and pull out an ECCS harness to divine what that bullet connector you have in your hand is.  What color is the wire going into the bullet?
