Guest Anonymous Posted January 19, 2002 Share Posted January 19, 2002 I'm changing from an external regulator alternator to an internal regulator 140 amp Cadilac model. My questions are: #1 "How are those CS Cadilac alternators triggered to put out juice? #2 Does the computer do it? #3 Or is it internally triggered like a one wire alternator? #4 I'd like to know what I have to do to use this alternator. I'm getting conflicting advise locally from two people That I value both their opinions. I'd appreciate some help on this one. Quote Link to comment Share on other sites More sharing options...
johnc Posted January 20, 2002 Share Posted January 20, 2002 Unfortunately I don't have answers to your question but I do wonder what electronics you have on your HybridZ that would require 140 amps? You must have an incredible sound system. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted January 20, 2002 Share Posted January 20, 2002 It's not for either of my Z's. It's for my 1969 panel truck that may one day have an air bag suspension with on board compressors and hopefully a K.A. stereo system some day. Quote Link to comment Share on other sites More sharing options...
pparaska Posted January 22, 2002 Share Posted January 22, 2002 Search on the forums here for the CS alternator stuff. I've posted some stuff about it here before. But to answer your question, you need to trigger the thing with a signal. I used a lead from the battery with a 12V lamp in series to the center small prong on the connector. That's the field energize terminal. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 8, 2002 Share Posted February 8, 2002 On that note, does anyone know of a GM vehicle that has a high current alternator I can scavenge for my LT1 Z? Quote Link to comment Share on other sites More sharing options...
Modern Motorsports Ltd Posted February 8, 2002 Share Posted February 8, 2002 Quote Originally posted by dewzenol:On that note, does anyone know of a GM vehicle that has a high current alternator I can scavenge for my LT1 Z? You should be able to have your Lt1 case rebuilt with a high amperage winding/setup. Standard chevy cases can be easily done and I'd assume yours could as well. Depending on the size of your case your local rebuilder can build it for some very respectable amps. Local large builder I checked out can do up to 200A's and above. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted February 9, 2002 Share Posted February 9, 2002 dewzenol, big Cadilacs have 140 amp alternators that idle at 55 amps. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted March 6, 2002 Share Posted March 6, 2002 Quote Originally posted by dewzenol:On that note, does anyone know of a GM vehicle that has a high current alternator I can scavenge for my LT1 Z? The stock LT1 alternator is 140amps...at least the ones on my 94 Z28 and 97 Camaro SS are. You might check some of the cop car Caprice alternators, they may be higher amp versions. Quote Link to comment Share on other sites More sharing options...
