280z tach with Ls 2 coils
  • 2 months later...
What are you using for an ECU to drive the coils? I believe that you need to connect the Positive lead that previously connected to the coil to a Tach output or auxiliary ignition feed from your ECU. But I'm not 100% sure on that...
This may vary for different ECU's ( MS, Haltech, AEM etc ), so those forums may have the answer if no one else chimes in.
