gravityflyer Posted July 31, 2015 Share Posted July 31, 2015 Hi all! Got a couple rookie questions for you... I'm reinstalling the original wiring harness on my '77 280Z and need some help ID'ing a couple items. (1) There are red and green wires running off the distributor. On a wiring diagram it seems to suggest that these wires run all the way to the passenger firewall and connect to the transistor ignition unit, however, I don't believe this is physically possible given the length of wire. Any thoughts on where it may connect to?(2) Perhaps related, albeit a separate question, what is this mini junction with red and green wires connected to it? Located on the driver side. As always, thank you! Quote Link to comment Share on other sites More sharing options...
NewZed Posted July 31, 2015 Share Posted July 31, 2015 Open up the mini-junction, look at the distributor wire ends, and all will be clear. Quote Link to comment Share on other sites More sharing options...
gravityflyer Posted July 31, 2015 Author Share Posted July 31, 2015 Gotcha! Okay, so hook the distributor wires to the mini-junction? I assume the wires then run from the mini-junction to the transistor ignition unit? Thanks again! Quote Link to comment Share on other sites More sharing options...
