evoog Posted October 9, 2015 Share Posted October 9, 2015 (edited) Bellow is the specs on the build, keep updating as life progresses, will do individual posts as work is completed. Car 1974 early production Datsun 260z Orange with SR20det from s13 chassis miles-70k approximatelyengine miles-10k approximately Instagram https://www.instagram.com/artofevan/ Future plans -ms3 -top mount turbo -finish air dam for v-mount -nrg steering wheel -corbeau seats -install a/f gauge -replace front and rear windows -replace rear defrost -brakes...seriously, need them -flares, spoiler, wheels, ugh, need go fast parts Current specs interior-Speed hunt tach 4", mechanical speedo, oil gauge, coolant temp, and fuel gauge all back lite blue -prosport 52mm mechanical boost gauge blue/white -interior mounted boost controller-custom dash w/ steel frame and aluminum coverings-avh 5600 pioneer radio-MSA rear mount speaker box-full MSA individual piece carpet kit w/ new sound deadening mat-"Z" front floor mats-hydraulic ebrake(stock ebrake still present and functional) -interior mounted rear brake bias valve -custom interior fuse panel, relay box, and pretty much every wire of electrical has been replaced-taylor rear mount battery box w/ redtop optima battery-all door and window seals replaced -vintage air 2 mini ac unit w/ defrost, four 2.75in dash outputs, two defrost outputs(utilizes stock defrost outputs) -full flocked dash and center console Suspension-full urethane bushings front and rear-urethane mustache bar-MSA sway bars front 1", and rear 7/8"-Motorsport street top hat camber kit front and rear-Eibach progressive lowering springs-KYB shocksExterior-HID classic headlight kit from dapper lighting v1-MSA front and rear stealth side marker kit -Rear bumper modified for flush fitment Steering-urethane steering coupler-quick steer knuckles-bump steer spacers for 15" wheels-Urethane rack bushingsFuel-Aeromotive stealth 15 gallon fuel cell with built in pump and fuel sending unit mounted in center rear under body-dual fuel cell vent filters-Aeromotive ss series inline fuel filter-AEM inline fuel regulator w/ gauge-New 3/8" hard fuel line for return and feed line-Full AN fittings with black braided line to/from fuel rail and to and from tank-Circuit sport gold side feed fuel rail-stock injectors w/ new sealsDiff/transmission-2004 r180 subaru lsd diff, new lsd, new ring and pinion, full rebuild w/ 260z input flange-beta motor sports stub axles-240z halfshafts w/ new u joints-ACT ns1-hdg6 clutch kit, heavy duty race sprung 6 pad-ACT flywheel 10.6lbs-Circuit sports v2 solid shifter kit-new clutch slave & master cylinder, hard line, and steel braided line-driveshaft is a 260z driveshaft, shortened, balanced, and had a sr20det input flange welded on by a diff shopcooling-3 row aluminum radiator-dual 10" curved electric fans with interior on/off push button -Z car depot aluminum fan shroud-s14 coolant outlet pipe -dif temperature sensor water neck adapter bung -Nizmo thermostatOil-S14 oil pickup-greddy drift oil pan w/ increased capacity and internal baffles-circuit sport oil filter relocation kit-Tomei oil block adapter-billet engine oil cap-neochrome oil catch can w/ black an lines and fittings on valve coverEngine-Purchased as a long block fully rebuilt and blue printed w/ stock t25-mines 62 stage 3 ecu w/ raised limiter, and tuned for mild bolt ons at 13-16psi -ebay cheapy interior mounted boost controller currently set at 12psi-3 inch full exhaust straight pipe -Megan racing downpipe modified-Megan racing turbo output-new sensors, belt, cas sensor, starter, ignitor chip, wiring, hoses(either black or orange)-freddy intake manifold-megan racing exhaust manifold bottom mount-HKS ssqv version 4 blow off valve-cx racing 3" front mount intercooler with 2.5" hoses & pipes-valve cover w/ an fittings for oil catch can, orange, shaved stock letters to just say "win"-custom spike valve cover nuts -TiTek carbon fiber spark plug cover-mckinney motorsports engine and transmission mount kit with poly mounts -V mount Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 9, 2015 Author Share Posted October 9, 2015 (edited) carbon fiber yummy Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 9, 2015 Author Share Posted October 9, 2015 (edited) The dash is fully flocked, and drying, seems to take 48 hours to fully set. The vintage air unit is mocked in place, one bracket welded in, one bracket finished just not welded, and one more to go. Dashboard & flocking. The flocking parts are hard to get a quality photo of them, they actually seem to absorb most of the light. Work progressing on the ac unit, running a little behind schedule at this point. Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 9, 2015 Author Share Posted October 9, 2015 (edited) tranny tunnel getting work in Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 15, 2015 Author Share Posted October 15, 2015 (edited) Finished the vintage air system. The vintage air only has the heater running, as no ac will be installed until summer. I am very impressed with the system, easy to wire, not to hard to install, and puts out a fair amount of airflow for its size. Just need a cold day to test it, cause apparently cali is undergoing a heat wave again...ugh Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 16, 2015 Author Share Posted October 16, 2015 (edited) reserved Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 17, 2015 Author Share Posted October 17, 2015 (edited) reserved Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 18, 2015 Author Share Posted October 18, 2015 (edited) reserved Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted October 25, 2015 Author Share Posted October 25, 2015 (edited) Painted the front end air dam parts, and all put together. Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
V-Fib Posted October 25, 2015 Share Posted October 25, 2015 Very creative with the air dam to channel air to the intercooler. Reminds me of the factory air dam I have on my Evolution. Quote Link to comment Share on other sites More sharing options...
evoog Posted October 27, 2015 Author Share Posted October 27, 2015 On 10/25/2015 at 1:36 AM, V-Fib said: Very creative with the air dam to channel air to the intercooler. Reminds me of the factory air dam I have on my Evolution. Thanks, dig the username Quote Link to comment Share on other sites More sharing options...
evoog Posted October 27, 2015 Author Share Posted October 27, 2015 (edited) reserved Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted November 2, 2015 Author Share Posted November 2, 2015 (edited) Installed a fan shroud, I dont know why previous me did not already install one. Apparently I was a cheap skate when doing the cooling system. Anyways its a Z cardepot fan shroud, listed for 12inch fans. I honestly already have 10 inch fans, and they cool my little sr20 quite well. Luckily, the 10 inch fans fit the shroud, the fan itself is smaller then the hole(think a 12" fan would fit perfect) yet the outside covers the hole and has plenty of edge for support(they fit which is what I care about). The shroud itself is very nice, and for the price, hard to beat. Still have to drive her around and see how this changes my temps. Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted July 22, 2017 Author Share Posted July 22, 2017 (edited) Forgot to post this, sorry for the poor quality photos. Got the radiator and intercooler v-mounted. Currently doing some street testing before the final weld and paint. Edited July 22, 2017 by evoog Quote Link to comment Share on other sites More sharing options...
evoog Posted July 30, 2017 Author Share Posted July 30, 2017 R&R the turbo to fix a broken stud. Welded the divider in the exhaust turbo outlet. Pressure tested the system and found a boost leak on the intercooler where the guy welded the new outlet. Going to have to send it out for repair. Installed a AFR gauge(no pics) Took her for a test drive and snapped the u-joint on the driveshaft. Warm days + sticky tires = all bad Quote Link to comment Share on other sites More sharing options...
evoog Posted August 19, 2017 Author Share Posted August 19, 2017 Sadly the slip yoke was trashed when the driveshaft u-joint snapped. Luckily my local diff shop had all the parts in stock and ready to go. The driveshaft is now fixed and back in the car. My brakes have been rubbish on this car since day one. Who would have guessed that 40 year old calipers and wheel cylinders would be junk? I mean common, they just are 40 years old. Bigger brakes are planned for the future, but just not in the budget right now. So in the mean time, some new stock reproduction brake parts were ordered. Ended up picking up some A1 cardone calipers for 25 each and some rear wheel cylinders for 27 each. The rear pads were junk so replaced those for 17, new springs for 9, and turned the drums for 15 each. The front pads and rotors were still prime, so those were salvaged. Found one of the rear cylinders was frozen and the other one was clogged. For less then 200 bucks the car now stops fairly well, has great pedal travel and pressure. Now that the car can stop, its time for more power Quote Link to comment Share on other sites More sharing options...
evoog Posted September 3, 2017 Author Share Posted September 3, 2017 Competition hood scoop is installed and the intercooler can finally vent properly. Still needs sanding and paint, but this will do for now. The installation was pretty straight forward, however the supplied nuts are a pain in the you know what. Quote Link to comment Share on other sites More sharing options...
1969honda Posted September 3, 2017 Share Posted September 3, 2017 Competition vent looks nice! Care to share your thoughts on the vendor you purchased it from and the quality? I think my build will require one down the road for venting and an extra inch or so of hood clearence. Quote Link to comment Share on other sites More sharing options...
