rolmsted Posted December 5, 2015 Share Posted December 5, 2015 I bought an almost complete EFI setup to swap into my 240z. But haven't been able to find the main efi relay. I have a complete carb set up that I just couldn't dial in. Possible partial trade? Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 5, 2015 Share Posted December 5, 2015 I bought an almost complete EFI setup ....... But haven't been able to find the main efi relay Early 280Z, late 280Z, or 280ZX? They all use a different EFI relay. If you studied the wiring diagram you'd probably realize that you can work around it. Half of the early Z relay is the fuel pump relay. Quote Link to comment Share on other sites More sharing options...
rolmsted Posted December 22, 2015 Author Share Posted December 22, 2015 Sorry got busy for last 2 weeks, its a 1975 set up, I was looking at the diagram and drew it up and saw its two separate relays inside one. I'm at work so don't have the diagram I drew, Ill come back and post tonight to make sure its correct. What amp relays would I need? Quote Link to comment Share on other sites More sharing options...
NewZed Posted December 22, 2015 Share Posted December 22, 2015 Match the fuses or go a little higher. There are two separate plugs to the dual relay, if you wanted to replace just half/one. Here's a potential source - http://www.datsunstore.com/relay-fuel-injection-7577-fuel-pump-p-735.html Quote Link to comment Share on other sites More sharing options...
redbull z Posted January 21, 2016 Share Posted January 21, 2016 I have a fuel pump relay for a 76 if needed Quote Link to comment Share on other sites More sharing options...
