brake lights wont turn off?
Brake switch. Brake switch adjustment. Short in the wiring. A broken turn signal switch (brake light wires run through the switch).
Check the simple things first such as the brake switch adjustment and the brake switch. The brake pedal in the up position pushes the brake switch open (no power flowing). When the brake pedal moves forward the brake switch springs to the closed position turning on the brake lights.
