CART0410 Posted January 4, 2016 Share Posted January 4, 2016 Hi I am trying to figure out what size and offset Volk TE37V wheels and tires will work best on my S30 with standard width ZG flares. If you have sizes and pictures please help. Thank you Quote Link to comment Share on other sites More sharing options...
makaofox Posted January 4, 2016 Share Posted January 4, 2016 Basically 15x9.5 -20 on all 4 corners will be flush with regular zg flares. I run 17in same size and offset and im flush with my flares with 235 toyo r1r. There is plenty of info on this sight and others as to what sizes you can go with. To avoid adapters and spacers you need negative offset. Quote Link to comment Share on other sites More sharing options...
veritech-z Posted January 4, 2016 Share Posted January 4, 2016 On a non-coilover suspension, it seems like 4.5" of backspacing is the most people are running without rubbing. That is the dimension you need to be most concerned with (at least for inside rub); in the aforementioned 15" X 9.5" -20 example, that is exactly 4.5" of backspacing. but that same -20 offset on a 10" wide wheel would put you at 4.75" backspace, and you'd likely be rubbing the suspension. Quote Link to comment Share on other sites More sharing options...
