Reverse Switch acting up
My reverse lights have been malfunctioning intermittently: when I put the car in reverse sometimes they light up and most times they don't.
I searched this forum and found nothing specific. I will go under the car and check/clean the connectors to the switch but if the problem persists I will have to source a new switch.
I've seen $10 switches from Black Dragon, $38 from MSA, $45 from Z Connexion (apparently Nissan OEM) to $70 ones from another site.
Any experience from the forum members with any of these? Are they all basically the same units or is there a true reliability difference among them?
Thanks all.
They are nothing special, it's just a switch, polarity doesnt even matter. Check your underhood connectionsfor them first, they can get corroded and start to suck. It's two bullet connectors, undo them, clean the contacts with some fine sandpaper or something similar and grease them/plug them back in and see if you get an improvement.
Are these connectors really "underhood" ? I thought they were located on the right side of the transmission.
