rags Posted March 17, 2001 Share Posted March 17, 2001 I'm trying to finish wiring the turbo motor and have hit a snag. Of the three pins on the TPS, which one gets 5v, which gets ground, and which is the TPS sensing wire? Thanks. Joe Quote Link to comment Share on other sites More sharing options...
SleeperZ Posted March 17, 2001 Share Posted March 17, 2001 The top wite is not used on a turbo, it signals WOT. The center pin is common, and the bottom pin signals idle. You only have to hook up the bottom two, but they should already be in your harness. Quote Link to comment Share on other sites More sharing options...
rags Posted March 17, 2001 Author Share Posted March 17, 2001 This is for a TEC II. There instructions call for connections described above. Thanks. Joe Quote Link to comment Share on other sites More sharing options...
